Looking for cylinder 89 kdx200
Duper80
Post by Duper80 »
I recently found an 89 kdx200 and stripped it down to the frame for a complete rebuild , during the motor teardown I found out the cylinder is complete trash (after finding jb weld holding it together ffs) I'm in canada and not having much luck finding another one , I could only find 1 on ebay and it's so dirty God knows what the grease and dirt is hiding lol... anyone have or knows someone who has one I could purchase and ship to nova scotia, canada??
Re: Looking for cylinder 89 kdx200
You might try speaking with the people at Millennium about their cylinder repair services. I understand they can fix most anything broken.
Post by kdxsully »
JB weld huh? I posted a video a while back of a guy running a lawnmower with a piston completely made of JB weld.
Doakley is right, they fixed some pretty nasty stuff, as long as it isn’t cracked all the way through or something
Has thanked: 66 times
Been thanked: 20 times
Check PowerSeal USA also.
Good luck on the search.
Duper80
Post by Duper80 »
Thanks for the info guys! I did end up finding one in great shape on ebay, I also ordered a sleeve and top end kit 👌..just replaced all the swingarm&linkage bearings and in the process of wet sanding then polishing until I can get back to the motor ✌
rungrandpa
Country: U.S.A.
Post by rungrandpa »
" I also ordered a sleeve"
I'm no expert here but most warn not to sleeve the KDX cylinder but have it replated if needed by Millennium.
Post by kdxsully »
rungrandpa wrote: 02:55 pm Sep 18 2019 " I also ordered a sleeve"
How come?
rungrandpa
Country: U.S.A.
Post by kdxsully »
rungrandpa wrote: 04:41 pm Sep 18 2019 viewtopic.php?t=8939
The powervalves?
Plating is better than sleeving, or Kawasaki would not have put it on their 1974 KX models and every KX cylinder since. I'll trust Kawasaki's call on it. :mrgreen:
I don't see how a sleeve goes well with an "E" cylinder, as it can not be ran in an overbored size due to the power valves being so close to the cylinder walls.
Unless for some reason a cylinder can not be repaired (welding / grinding, etc.), then replated, I think most recommend a replate.
The number of people that can drill a hole and shove a tube down in it is a WHOLE LOT more than companies that have the equipment for plating.
Duper80
Post by Duper80 »
Thanks for your input guys! after searching on forums and info/advice on here I decided to go with replating my cylinder and trying to find a reputable shop in my area to do the work (which is easier said than done) I'm in Canada if anyone can recommend a shop here or if not the best place stateside would be greatly appreciated!!
Make a new thread asking about Canadian businesses that replate. It will catch more attention than this thread title. There are a few people on here from Canada.
