There are rules...and there are damn rules...
One of the 'rules' is, believe nothing of what you hear and half of what you see. An addendum for the fairly literate amongst us (are there any??)...believe not a whole lot of what you READ, neither.
1. I spent the afternoon trying to adjust the chain slack on MY streetbike. I never
found the dang thing!! And...no....there's no RUBBER BAND attached to the rear wheel, neither.
For starters...according the jenuwine service Manuel (that's the guy's name that works on my bike. Heck...no AMERICAN will do the job!!!):
Put your bike on the side stand. If your suspension is adjusted correctly, that means your shock will be topped out..all of your
free sag will be gone.
Measure the distance from the swingarm to the bottom of the extended (hold it up!) chain at the end of the chain slipper. Spec is 55-65mm. In the real world that means 2.165-2.559".
Free sag being gone, you will have the same situation with the bike on a center stand, rear wheel off the ground. **edit** Unless your unitrack kuckle (rear suspension) is trashed.
If you're running 1 1/2"...it is
too tight!!
Now then...for the
best oil.....
