Front hub difference 89-92 vs 93-94
Posted: 02:39 pm Sep 02 2019
by Jasper
Hello
Can you put the front hub from a conventional fork from a 89-92model into the upside down forks of a 93-94 model ?
Re: Front hub difference 89-92 vs 93-94
Posted: 03:27 pm Sep 03 2019
by Jasper
Posted: 07:00 pm Sep 03 2019
Sorry. I haven't tried it.
Posted: 05:42 pm Sep 04 2019
by bufftester
You can use the front wheel from any 86-2007 KDX200/220. They all have the same diameter axle. The left side collar is also the same for all E/H/220s. The only difference between the pre-93 and post 93 is the gear drive for the odometer, but I believe they are the same size anyways. So short answer is yes, but you may need to adjust the spacers for the right side.
