Piston
- Country: England
Piston
I bought a kdx 220 quiet clean inside my piston has A top I take it this is standard
- ED4A617A-8644-4AAB-9DEA-923EA198AA5E.jpeg (1.78 MiB) Viewed 2275 times
- 3421358E-A9FE-4001-95CC-40AB7E8F719F.jpeg (1.65 MiB) Viewed 2275 times
- 625FCC02-C777-424D-AAB9-240FBBBE2B1B.jpeg (1.79 MiB) Viewed 2275 times
Re: Piston
That looks like the stock piston.
Did the previous owner mention head work? Does a stock head look that good??
- Country: England
Re: Piston
Totally standard wiseco piston arriving tomorrow bike only done 4000 miles I put motul 5100 in gearbox 10/40 the clutch slipped really bad
Re: Piston
Did you clean the piston top while it was still attached? Sounds risky.
Measuring the piston diameter before ordering another piston would have been a good thing, just in case.
Which 10w-40 did you use?
I am a big fan of putting motorcycle oil in motorcycles.
Re: Piston
If gearbox oil has friction modifiers, this may cause clutch slippage. Many on this forum use ordinary Type F ATF with good results.
- Country: England
Re: Piston
I put this in it foooooked the clutch
- Kdx not like this
- BCC42743-A024-40A9-BC04-4FFB6AC92317.jpeg (1.97 MiB) Viewed 2252 times
Re: Piston
That should be fine, it's rated for wet clutch. I would check your clutch spring free length and the disc thicknesses.
Re: Piston
+1 for atfpumpguy wrote: 09:39 am Jul 01 2019 If gearbox oil has friction modifiers, this may cause clutch slippage. Many on this forum use ordinary Type F ATF with good results.
- Country: England
Re: Piston
You lot over there seem to like ATF oil never used it before but seems to work well on reviews so will try it soak new clutch overnight
- Been thanked: 10 times
Re: Piston
Look, a factory Kawasaki grenade!Parney wrote: 02:10 am Jul 01 2019 I bought a kdx 220 quiet clean inside my piston has A top I take it this is standard
Yep, that should have worked just fine. Like was mentioned, measure everything to see if all is in spec.bufftester wrote: 04:38 pm Jul 01 2019 That should be fine, it's rated for wet clutch. I would check your clutch spring free length and the disc thicknesses.
+2
Re: Piston
I use the Honda "red bottle" HP transmission oil
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
