1993 kdx 125 UK model has no spark
Posted: 04:40 am Apr 27 2019
Hi guys, I've joined this forum as I purchased a old kdx a few weeks ago. Now the bike was hard to kick start when I picked it up and by hard to kick start I mean I had to repeated kick it and that still didn't start it. In the end we pushed it and bump started it which worked and got me home. After a few days I cleaned the carb and bought a new air filter and got the bike running very well. It still took alot of kicks while cold even with the choke on but once running and warm it ran great and kick started well for 20 minutes or so.
Then I tried to re start the bike half hour later and it wouldn't start at all. I pulled the spark and it had no spark. I tried a new plug and a new coil both of which didn't solve the issue. I'm trying a new although second hand CDI today to see if this solves the problem.
If the CDI replacement dosnt solve the problem could it be the regulator? Or is it then almost certainly the stator. I've already contacted a company who will fix the stator and re wind it for £130 but don't want to go straight to that incase a regulator could also cause no spark?
Any advice would be greatly appreciated and I will post an update in a couple hours after fitting the new CDI.
Thanks
Thanks
