Shift turret very sticky [pics!]
Posted: 09:38 pm Apr 24 2019
Hi all,
I just got a new (old) bike.
I am taking the engine out/apart currently because of the following problem:
Gear shift shaft splines are completely fudged. (edit)
I took out the offending component. However, as I try to shift through the gears by spinning the shift turret with a phillips (while turning the crank), it seems not smooth, or takes some finagling to get it to go through the gears.
I have never even ridden the thing, I don't have much to compare it to.
See these photos.
https://photos.app.goo.gl/NCrXUheuVoy1DAw17
Is this normal? I was hoping the shift shaft splines were from a hard kick from the previous owner, not just a symptom of a deeper problem. Seems I may not be so lucky?
My strategy may be to just button it up and try it out before I go off on a crank splitting tangent. I have a new gasket coming in the mail, a new gear OEM gear shifter, and am trying to haggle on a shift shaft with a guy...
See these photos.
