Auto clutches?
Posted: 04:21 pm Feb 07 2019
by robkdx
Thinking of pulling the trigger on a EFM auto clutch.
When changing up do you just come off throttle and shift? And same down?
Re: Auto clutches?
Posted: 04:49 pm Feb 07 2019
by doakley
Yes. No problem at all. I love my EFM.
Re: Auto clutches?
Posted: 07:53 pm Feb 07 2019
by robkdx
doakley wrote: 04:49 pm Feb 07 2019
Was it hard to fit?
Re: Auto clutches?
Posted: 08:29 pm Feb 07 2019
by doakley
I got mine used from another kdx owner on these forums. It was a simple “drop in” for the stock clutch. It comes with a spacer and longer case bolts. You’ll have to devise a way to seal off the hole where the OEM clutch mechanism goes there the top of the case. I used a bike and nut with appropriate washers and a rubber seal I cut from an old inner tube.
Re: Auto clutches?
Posted: 10:30 am Feb 09 2019
by G22inSC
Rekluse here instead of EFM but as to your question, I still use the clutch for shifting gears.
Re: Auto clutches?
Posted: 07:31 pm Feb 13 2019
by robkdx
G22inSC wrote: 10:30 am Feb 09 2019
EFM deletes the clutch so none to use.
