Oh and Happy B'day Ron...
Float level on Aistriker
- KDXer
I'm curious as to whether anyones Airstriker pees like the standard PWK does ?? I know it is a float height issue but does Ron set them himself or do they come set pretty good ??
What is set in his shop and what you get 'in the mail' doesn't necessarily have to be even faintly related.
I'd suggest always at least checking them after shipment.
As far as, 'Do they pee?'.. my personal experience is, 'Yes.' As the OEM PWK, a set level in the 'low spec' range will work better than a 'high spec' range.
A more upright kickstand (aftermarket) was probably the best resolution in my case.
Yep..Happy Birthday indeed (last weekend)!!
- skipro3
I re-set my float level by no calibrated method, but instead, just gave the tab a good bend and felt where the close point was and noted the float angle. No more pee for me!!! If the KDX was a thirstier bike, this might cause a problem, but the petcock supplies the bowl with enough fuel for this motor without starving it even if the float level is set on the low side.
- KDXer
I set my tab but the bike kept peeing when it was leaned over on the kickstand. I thought about getting a longer stand but didn't want to spring for it.
Instead, during my last high-altitude re-jetting chore, I looked at the float and worked it up and down. I found that one of the floats (the right one in my case) was a bit higher than the left one. The right float would hit the top of the bowl before the left one. I bent the right one down to match the left, and viola. No more pee (for now).
Rick
Rick
As long as we're here....
If you are having float problems (peeing being one symptom)..check for a leaking float, too.
Good observation!!
Uh...Kaydee is still waiting for parts since March?
Surely he would have posted a resolution had there been one.........
Good observation!!
- skipro3
Haven't heard from Trev in a while.............
You still single? If so, come to California. The house will be finished next month. There is already one wedding planned. A family friend thinks it would make a great place to hold a wedding!
Just to keep from hyjacking;
PEE
There.
PEE
There.
