2000 KX125 forks tuning, restrictive barrier?
robkdx
Post by robkdx »
Im about to pull our my 2000 kx125 forks for seals.
I keep reading about removing the restrictive barrier, can anybody point me to where it is and what to do with it?
Has thanked: 49 times
Been thanked: 15 times
Re: 2000 KX125 forks tuning, restrictive barrier?
The white plastic ring
Post by John_S »
http://www.kdxrider.net/forums/viewtopi ... 86&t=22433
The picture with the forks disassembled has the white plastic ring in the lower left corner. Removing that is easy and it disables the bladder. I removed the bladders also which are the black rubber tubes also in that picture. Jason would know whether removing the white ring is all that needed or removing the bladders helps also. Servicing them in the future will be easier (cleaner anyway) without the bladders.
Yeah, either way they say.
I put some 2000 KX125 forks on my friends KDX with an Emig Racing stem.
I pulled the bladders, but read later one could just do the white plastic ring.
Oil level and quantity are affected by pulling the bladders.
robkdx
Post by robkdx »
Ah righto. My bladders are long gone. I was reading it was something on the rebound valve that needed to be ground into a petal shape.
I haven't read that.
robkdx
Post by robkdx »
I have since worked out the barrier is the white ring. Or you just put a washer under the spring so it doesnt cover the transfer ports.
KDXGarage wrote: 10:41 pm Sep 29 2018 The white plastic ring
posted the same day you asked??
