G'day everyone, I recently picked up a 92 kdx250 and was wondering what kind of parts are interchangeable between all the kdx's for the 250, more specifically I'm chasing a kicker and a coolant reservoir for mine, if anyone happens to have these parts and would consider selling them that would be greatly appreciated.
Cheers for now.
1992 KDX250SR Interchangeable Parts
- Country: Australia
- 6 Riders
Re: 1992 KDX250SR Interchangeable Parts
I believe that the KX250 has more interchangeable parts than other kdx models. You have to check for your self though.
Look on an Australia online dealer website for the parts diagram for diagrams of your model. Use those part numbers to see which other models came with the same part.
If you want info on what is a different part number and will work, that info will be hard to come by for an SR version, I am afraid.
- Country: Japanese version
Not alot out there, and be careful ordering parts that say they will fit sr and they won't... clutch, sr has one different size friction.. I tried a seat cover for sr , didn't fit, kx 500 will, fork seals, wrong, gasket kits wrong.. not cattering for bigger cases counter shaft. Piston is not available... wrist pin is 19 mm instead of 18mm . Front brake lever is different.. eBay is what I use most
