Does anyone know of a cush drive hub that will, or might, fit a KDX 220 swing arm with reasonable hope that the sprocket and rotor will line up similar to OEM hub?
Since this would be an experimental project, I'd rather find a used assembly rather than going all new.
Reason for asking is, back in the day I had a bike with direct drive break the gearbox cases. Was trying to resolve a slipping clutch problem and after beefing up the clutch, took it on the street to check for slipping. Well, the clutch no longer slipped, the cases broke instead.
I have to admit I really thrashed it, and the failure was totally my abuse. Still, I think a cush in the drive might have saved the day.
I've also seen something about cush sprockets (Kush sprockets). Anybody know anything about these? Could a guy make his own if he really tried?
Cush drive for KDX 220
- Country: UNITED STATES
Re: Cush drive for KDX 220
With all due respect, I think you might be trying to fix a problem that doesn’t exist.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
I've heard some KX rear wheels fit directly onto the KDX. I haven't yet verified this for myself. Assuming that is true, it is probably more likely to find one for a KX 125/250 and it will fit on the KDX. However, the ones I've seen on eBay were new and quite expensive.
Yeah, you're probably right. Sometimes I overthink things. Past experience with old road and dirt 175 and 250 2T bikes with cush drives was a smooth power delivery. Most noticeable on pavement. KDX seems a bit snatchy by comparison.david wrote:With all due respect, I think you might be trying to fix a problem that doesn’t exist.
Knobby tires in the dirt provides all the cush needed; trying to smooth things out a bit on pavement.
Not seen any specific to the smaller bore bikes, but you may be able to find a later model Suzuki DR650 rear wheel fairly cheap, it runs a cush hub. The DRZ400s do not.
Thanks,
I'll look into that if I decide to pursue this project.
Also the DR350 had a cush drive, and might be a closer match size wise.
