92 kdx 200 clutch spring bolts keep backing out while riding
Mikebike203
Post by Mikebike203 »
I have a 92 kdx 200 my clutch spring bolts keep backing out while riding and hitting the case cover. It has happened twice while riding. Out of the 5 bolts 3 of them back out/ loosen up. Can anyone help me?
Re: 92 kdx 200 clutch spring bolts keep backing out while ri
Use some blue loctite (not red), and make sure you are torquing them to the proper spec.
WOW
Welcome to kdxrider.net.
Mikebike203
Tried blue loctite this past time and i did tourqe them down to spec but I'm stuck. Going on a trip and dont want anything to happen while on the trails :?
jjavaman
Post by jjavaman »
Are there washers missing?
When you applied your loctite did you do it with the clutch still in the bike or did you remove the basket, clean it up and make sure there was no oil in the threaded holes first? If you installed the loctite in the bike with oil wetted threads it won't do anything. That said, I've never had those bolts come loose on any of our KDX's. Using the OEM screws and springs I assume?
Mikebike203
I did make sure there was no oil in the holes, it seem to have worked for the mean time. Is there some kind of bracket or washers something that hold those bolts in place? wondering if i might be missing something. the bike was previously taken apart by the previous owner and never put back together before i got it. i did check some diagrams but none of them showed anything i didnt already have. sorry about the late response,, been a bit busy.
