What to do with Pipe Supports
morganid
Post by morganid »
There is a pipe mount/support right below the gas tank and another one at the bottom of the pipe, close to the cylindar. I had a KX500 that would eat through these. I could never keep them on the bike in one piece. The rubber would shear. I figured it was because of the brain-rattling vibrations from that bike. KDX however, doesn't vibrate that bad. I noticed the one below the tank was sheered a couple years ago. In my frustration, I drilled through it an bolted it back together. (See picture. Bolt with 2 nuts is my mod) Yesterday, I noticed the other one sheered.
Any of you guys have this problem? What do you do about it?
Re: What to do with Pipe Supports
Replace or repair. Over time, they do fail. Yours are 15 years old, right?
I drilled through and bolted both of mine.
morganid
Post by morganid »
Yeah. My bike is an 03. On my 500, it seemed I replaced them on a yearly basis. Didn't even bother on the KDX. Good point though about it being 15 years old. Maybe they will last longer on the KDX.
Has thanked: 5 times
Been thanked: 12 times
The drill and bolt method works great. As a bonus, you get some adjustment from the mounts that you didn't have before.
