Speedometer Drive on Axle Position
Posted: 09:17 am May 13 2018
by firsthere
The repair manual and the owners manual (which comes with the bike) picture the cable pretty much vertical off the axle. Further on in the repair manual under the front wheel section it shows the cable routed further back, parallel with the fork. It would seem better routed and protected in that position. Which way are most owners setting the drive hub or does it matter?
Re: Speedometer Drive on Axle Position
Posted: 02:22 pm May 13 2018
by doakley
Hmm, when I had a stock front wheel prior to the KX conversion, I always put mine parallel to the forks, even though I did not have the cable connected any longer.
Posted: 03:15 pm May 13 2018
by John_S
I only have experience with the H series. There is a tab on the back of the fork leg a slot on the speedo drive that fit together. That puts the cable inlet about parellel with the forks.
Posted: 06:05 pm May 13 2018
Yes. He is correct. Look for the slot and tab.
Posted: 08:05 pm May 13 2018
by firsthere
I noticed the slot for the tab. That matches the angle on my 650r speedo. Honda routes the cable to the outside of the fork tube though.
Thanks!
Posted: 11:33 pm May 13 2018
What is "Honda"?? Never heard of it.
Posted: 08:18 am May 14 2018
by firsthere
Its one of those Asian knockoffs, very heavy with valves and stuff.
Seriouskly though I was comparing its speedo routing as a reference for the KDX.
