Stator cover and gas smell
Kngnthn76
Post by Kngnthn76 »
I removed my stator cover and the smell of gas was very strong. I didn't see anything in there but the flywheel is in the way. Would this be a crank seal issue?
Has thanked: 5 times
Been thanked: 12 times
Re: Stator cover and gas smell
Almost certainly. Unfortunately the cases must be split to get to the seals. If you grab the flywheel, does it have any up down left right play? Normally bearing slop is what causes the seal to fail.
pumpguy
Post by pumpguy »
There have also been cases of fuel leakage along the wires and through the grommet. Check the area around where the wires exit the stator housing to see if this area is dry or not.
kdx633
Post by kdx633 »
many kdx's have porosity in the casting behind the stator.Jeff Fredette even addresses this in his care and maintenance video.Remove the stator and carefully inspect the path of the leakage,The source will be obvious.
Kngnthn76
Post by Kngnthn76 »
Julien D wrote:Almost certainly. Unfortunately the cases must be split to get to the seals. If you grab the flywheel, does it have any up down left right play? Normally bearing slop is what causes the seal to fail.
No side to side but maybe a little up and down play.
Timtee
Post by Timtee »
Kngnthn76 wrote:No side to side but maybe a little up and down play.
Not good. Time to split the cases.
Kngnthn76
Post by Kngnthn76 »
I was afraid of that. Looks like a full rebuild is coming. At least it is running and not locked up.
Kngnthn76
Post by Kngnthn76 »
Anyone used Ken O'Conner for crank rebuilds and jug replating?
Never used Ken. I've always used Andrew Cooksey of Cooksey Crank for my cranks and Millenium for my plating. There is really only a couple of places in the USA that do the plating and everyone else just subcontracts the work to one of them.
You MIGHT want to do a pressure test and vacuum test before splitting the cases.
Kngnthn76
Post by Kngnthn76 »
Jason wrote:You MIGHT want to do a pressure test and vacuum test before splitting the cases.
Never done that before. What is needed to perform the tests?
I can't stop myself...a pressure / vacuum tester. :kick: SORRY. :mrgreen: :razz:
Some have made a home made tester. Here's a pic of the real deal.
https://www.cyclegear.com/accessories/m ... OxEALw_wcB
Post by John_S »
Becuase of the cost of the real deal I went to ace hardware. This one cost me $40-50 and the bulb is $5 from Amazon. You could also use a schrader valve instead of the bulb but make sure you don't use compressed air to pump it and remove the air pump when you do test it incase the pump itself loses pressure. This is for pressure only. I've never vacuum tested one but need to figure that out for the future.
In addition to this I got a 1 3/4" expansion plug from the auto parts store to block off the exhaust port.
You pump it up to 7psi for 7minutes. It's important to do before tear down and before the exhaust and carb goes back on a rebuilt top or bottom end. I source the air leak until it's zero loss at 7 minutes (or however long I leave it there). I've read that 1 psi loss is acceptable but I don't know for sure.
If you have any questions about making one or doing the test feel free to ask.
Timtee
Post by Timtee »
Pressure test isnt going to do anything for the play in the crank bearings.
Post by John_S »
Check out this article on leak down testing and air leaks. At the end of the article they say they offer the kit for $39. I also made an all pvc one for cheaper than the brass version but would've paid $39 from Klemm if I knew they offered it.
http://www.klemmvintage.com/airleaks.htm
Post by John_S »
Timtee wrote:Pressure test isnt going to do anything for the play in the crank bearings.
The before and after test is to see if it was leaking before you take it apart so you know to double check that area when it's back together. Definitely not going to fix crank bearings.
Compression and leak down tests on the engine thats getting ready to be rebuilt gives you baseline numbers.
Who said it was?? :hmm:
Timtee
Post by Timtee »
The cases need to be split to fix the bearings. No need to waste time testing the worn engine.
It is best practice to test the rebuilt engine - but it isnt a necessity. Most peole dont and are fine.
How does a main bearing have this?? How can it be up and down and not side to side??
david
Country: UNITED STATES
Post by david »
Because when you are checking side to side, you are testing both bearings at the same time. If one is good, it will hold the crank in place. When you are checking up/down play, you are only testing the bearing that you are prying on (in this case, the stator side).
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
