brass o ring exhaust removal
Posted: 05:20 am Mar 15 2018
by deepwoods
hi guys, I want to change the brass o ring in the exhaust outlet in the cylinder, it seems flater :grin: than the new oem ring I have besides me, and seems very stuck, I don't want to go hulk on the thing, so do you seasoned kdx guys have any tips for removal? thanks
Re: brass o ring exhaust removal
Posted: 06:04 am Mar 15 2018
The copper C R U S H gasket?? :grin:
The one that when new is somewhat thick, but gets crushed during installation?
A hook tool can be used to remove the old one. Take a picture of the new one. It will never be the same after use.
:wink:
Posted: 07:22 am Mar 15 2018
by deepwoods
hehe good one Jason, I will try to remember its correct name from now on ! :grin: ok will look after hook tool , you Americans up already? its 1320 o'clock here in Norway now :wink:
Posted: 01:18 pm Mar 15 2018
by Molly's 70
I also use a hook type tool.
Posted: 01:59 pm Mar 15 2018
by deepwoods
yes if any of you could show a pic off the tools you use to remove it would be awesome :grin:
Posted: 03:47 pm Mar 15 2018
Posted: 04:04 pm Mar 15 2018
by deepwoods
thanks! :grin:
Posted: 04:16 pm Mar 15 2018
There should be some similar brand in Norway.
Posted: 04:17 pm Mar 15 2018
by deepwoods
yeah sure but if not I can buy it from eBay
Posted: 10:59 pm Mar 15 2018
by Mach2nh
In a pinch take a junk fork and snap off all but one prong then bend the tip over to make a pick.
Posted: 01:20 am Mar 16 2018
by deepwoods
thanks mach, Thats clever too :grin:
Posted: 01:40 am Mar 16 2018
Mach2nh wrote:In a pinch take a junk fork and snap off all but one prong then bend the tip over to make a pick.
Welcome to kdxrider.net, MachGyver. :bravo:
Posted: 10:12 am Mar 16 2018
by deepwoods
thanks guys, I have a little problem, now that the new copper crush ring is in my pipe won't go as far back as when the flat sat in there..will it become flatter over time, or should I pound the pipe backwards with a rubber hammer?? I can see that my muffler won't close into the pipe as much as before. 2.3 mm maybe. am I overthinking this? :cry:
