drainbolt plug carb
Posted: 08:24 am Mar 08 2018
by deepwoods
hi guys, the 17 mm drain bolt at the bottom off the float bowl on the H series, can I get access to both the main and pilot jet thru it? or just the main? thanks
Re: drainbolt plug carb
Posted: 08:32 am Mar 08 2018
main only
Posted: 10:32 am Mar 08 2018
by deepwoods
thanks Jason, I have a modded float bowl from adam Millar that might work, so much easier
Posted: 03:09 pm Mar 08 2018
You're welcome.
How is it modded?
I have a 2005 KX250. The carb on it allows both, so I have seen it before.
