drainbolt plug carb
deepwoods
Country: Norway
drainbolt plug carb
Post by deepwoods »
hi guys, the 17 mm drain bolt at the bottom off the float bowl on the H series, can I get access to both the main and pilot jet thru it? or just the main? thanks :grin:
KDX 200, 2001 model
Re: drainbolt plug carb
main only
deepwoods
Country: Norway
Post by deepwoods »
thanks Jason, I have a modded float bowl from adam Millar that might work, so much easier
KDX 200, 2001 model
You're welcome.
How is it modded?
I have a 2005 KX250. The carb on it allows both, so I have seen it before.
