rear wheel
kaw818
rear wheel
Hows it goin guys....need help locating a rear hub tube for a 2002 kdx220...i have an aftermarket wheel by RAD Mfg who are now out of business..The wheel is actually for a klx or klr which was interchangeable...somewhere along the line that tube was misplaced...what i have in there is not long enough affecting the ability to tighten up the wheel correctly...hub part #'s are identical from a klx, klr and the kdx....would this mean that the tube would also be the correct size for my bike...the part numbers on the tube itself dont match...im not sure what i should get...its been awhile and i dont know what exactly this wheel needs to be tightened up. thx
- Has thanked: 66 times
- Been thanked: 20 times
Re: rear wheel
Are you talking about the collar between the bearings?
Welcome to kdxrider.net.
Re: rear wheel
Sounds like you mean the collars for either side of the hub between the hub and the swingarm. 92143-1259 on this diagram REAR HUB. If so they are readily available (and used on a ton of different models)
kaw818
Re: rear wheel
thanks guys....it was the collar between the bearing....i had one in there that was a bit short....have since gotten another one and she's all tightened up
Re: rear wheel
Cool. Good job. Thanks for reporting back.
