will e series wide front fender fit the h series?
deepwoods
- Country: Norway
hello, I am trying to find out if the 89-94 kdx wide fender will fit the h series, and do I have to find a oem 89-94 one or does ufo,acerbis make the wide for the h series? thanks
KDX 200, 2001 model
- Has thanked: 66 times
- Been thanked: 20 times
Yes.deepwoods wrote:hello, I am trying to find out if the 89-94 kdx wide fender will fit the h series
I know UFO does. Look for the 1992 and older KX fender. Someone a few months ago on here said that UFO lime green is now 2005+ shade of lime green. You may want to check to be sure.deepwoods wrote:do I have to find a oem 89-94 one or does ufo,acerbis make the wide for the h series? thanks
Don't forget to pop rivet the cable guide from the OEM fender onto the aftermarket.
deepwoods
- Country: Norway
Re: will e series wide front fender fit the h series?
thanks for the reply, so 1992 kx fender will fit then? I had a 1990 kx 125, and that is the kind of fender I want, thanks also for the pop rivet comment, not all of us think off stuff like that. hats off to you.
KDX 200, 2001 model
You're welcome. Thanks for motivating me to look around and learn more on KDX's.
What year KDX200 do you have? Do you have the stock fender on it? In summary, if you have a 1995 - 2006 KDX with the stock narrow fender and stock bracket, you can get an aftermarket wide fender and transfer the bracket over.
If you look on Dennis Kirk's website (store, www.denniskirk.com), they show some fitment on aftermarket parts. The wider front fender was the same on back to the real early '80's.
I looked a little deeper. The 1989 - 1991 KDX200's did not have the bracket on the side. It is the same fender as the KX's. I would bet the later "E" fenders are the same, just WITH the bracket. At the same time, the 1993 - 2002 KX front fender may be the same as the 95+ KDX / KLX front fender without the bracket.
I didn't see an Acerbis wide front fender, just the narrow one (1993 - 2002 KX style).
Here's the KX / early "E" KDX fender model fit from Partzilla:
Kawasaki Motorcycle 1980 KX420 - KX420-A1 FENDERS
Kawasaki Motorcycle 1981 KX125 - KX125-A7 NUMBER PLATE/FENDERS ('80 A6)
Kawasaki Motorcycle 1981 KDX175 - KDX175-A2 FENDERS ('81-'82 A2/A3)
Kawasaki Motorcycle 1981 KDX175 - KDX175-A2 FENDERS ('80 A1)
Kawasaki Motorcycle 1981 KDX250 - KDX250-B1 FENDERS ('81KDX250-B1)
Kawasaki Motorcycle 1981 KDX250 - KDX250-B1 FENDERS ('82 KDX250-B2)
Kawasaki Motorcycle 1981 KX420 - KX420-A2 FENDERS
Kawasaki Motorcycle 1981 KDX420 - KDX420-B1 FENDERS
Kawasaki Motorcycle 1981 KX125 - KX125-A7 FENDERS ('81 A7)
Kawasaki Motorcycle 1981 KX250 - KX250-A7 FENDERS
Kawasaki Motorcycle 1982 KDX450 - KDX450-A1 FENDERS
Kawasaki Motorcycle 1982 KDX175 - KDX175-A3 FENDERS ('81-'82 A2/A3)
Kawasaki Motorcycle 1982 KDX250 - KDX250-B2 FENDERS ('82 KDX250-B2)
Kawasaki Motorcycle 1982 KDX175 - KDX175-A3 FENDERS ('80 A1)
Kawasaki Motorcycle 1982 KDX250 - KDX250-B2 FENDERS ('81KDX250-B1)
Kawasaki Motorcycle 1982 KX125 - KX125-B1 FENDERS
Kawasaki Motorcycle 1982 KX250 - KX250-B1 FENDERS
Kawasaki Motorcycle 1983 KDX250 - KDX250-B3 FENDERS
Kawasaki Motorcycle 1983 KDX200 - KDX200-A1 FENDERS
Kawasaki Motorcycle 1983 KX250 - KX250-C1 FENDERS ('83 KX250-C1)
Kawasaki Motorcycle 1983 KX500 - KX500-A1 FENDERS ('83 A1)
Kawasaki Motorcycle 1983 KX125 - KX125-B2 FENDERS
Kawasaki Motorcycle 1984 KDX200 - KDX200-A2 FENDERS
Kawasaki Motorcycle 1984 KDX250 - KDX250-B4 FENDERS
Kawasaki Motorcycle 1984 KX500 - KX500-A2 FENDERS ('83 A1)
Kawasaki Motorcycle 1984 KX250 - KX250-C2 FENDERS ('83 KX250-C1)
Kawasaki Motorcycle 1985 KDX200 - KDX200-A3 FENDERS
Kawasaki Motorcycle 1986 KX125 - KX125-E1 FENDERS
Kawasaki Motorcycle 1986 KX500 - KX500-B2 FENDERS
Kawasaki Motorcycle 1986 KX250 - KX250-D2 FENDERS
Kawasaki Motorcycle 1987 KX125 - KX125-E2 FENDERS
Kawasaki Motorcycle 1987 KX250 - KX250-E1 FENDERS
Kawasaki Motorcycle 1989 KX125 - KX125-G1 FENDERS
Kawasaki Motorcycle 1989 KDX200 - KDX200-E1 Fender
Kawasaki Motorcycle 1989 KX500 - KX500-E1 Fender
Kawasaki Motorcycle 1989 KX250 - KX250-G1 FENDERS
Kawasaki Motorcycle 1990 KDX200 - KDX200-E2 Fender
Kawasaki Motorcycle 1990 KX500 - KX500-E2 Fender
Kawasaki Motorcycle 1990 KX125 - KX125-H1 Fender
Kawasaki Motorcycle 1990 KX250 - KX250-H1 Fender
Kawasaki Motorcycle 1991 KX500 - KX500-E3 Fender
Kawasaki Motorcycle 1991 KDX200 - KDX200-E3 Fender
Kawasaki Motorcycle 1991 KX250 - KX250-H2 Fender
Kawasaki Motorcycle 1991 KX125 - KX125-H2 Fender
Kawasaki Motorcycle 1992 KX125 - KX125-J1 Fender
deepwoods
- Country: Norway
hi, i have a bone stock 2001 kdx 200. just bought the fmf woods gnarly, are are about to get to the jetting, and dial the bike in, its not bad stock, but one can feel that kawa didn't want it to take any chances jetting wise, I thought I will start with 45/158.what do you think..will the pilots from the keihin carb in my cr 500 fit? pilot and main? thanks for the fender info!
KDX 200, 2001 model
I think there are two types of pilot jets for Keihin carbs. I don't know what is on a CR500. You may want to start a new thread on jetting, as no one that may have ideas will see it in a thread title about fenders. There is a thread on how to go through the jetting. I don't have it handy.
deepwoods
- Country: Norway
ok i will try that .thanks
KDX 200, 2001 model
