Jet Block Gasket.
Posted: 04:16 pm Feb 13 2018
by Molly's 70
Should I just install the jet block gasket as it came out of the package? Or, is there a better way to re-assemble my carb. Looks like my gasket was ok, bike runs fine. I'm replacing it because it's 15 years old. Well, I just wanted to. I've never changed one before. Thanks in advance. JB
Re: Jet Block Gasket.
Posted: 04:20 pm Feb 13 2018
by bufftester
Just as it came. It can be a bit tricky to get it on there and the block back on, I used a tiny dab of vaseline to help hold it in place. That's how I ended up doing my KLX300 engine rebuild, just because I wanted to and had never done a 4T lol
Jet Block Gasket.
Posted: 04:27 pm Feb 13 2018
by Molly's 70
Thanks, I wondered about a dab of grease or something similar. Thanks!!!
Jet Block Gasket.
Posted: 04:31 pm Feb 13 2018
by Molly's 70
Ok, What's a 4T?
Posted: 04:36 pm Feb 13 2018
It's an engine style when simplicity and lack of parts just won't do.
I am just kidding. They are quite nice. My push lawn mower has one. I assume a motorcycle with one would be very similar, when anything goes wrong, just go buy a new one.
Jet Block Gasket.
Posted: 04:43 pm Feb 13 2018
by Molly's 70
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
Oh, I was just kidding.
Posted: 06:54 pm Feb 13 2018
by bufftester
Jason wrote:It's an engine style when simplicity and lack of parts just won't do.
How painfully close to the truth that cuts
Posted: 01:55 pm Feb 14 2018
by raygun
I've never understand why 4T and 2T uses a T? If we say 4 stroke why not 4S?
Posted: 06:26 pm Feb 14 2018
by tmmyghst
My original gasket had sealant, I used Permatex High Tack Gasket Sealant.
Some install without anything.
Must be ok either way as I don't hear of failures after installation.
Jet Block Gasket.
Posted: 07:17 pm Feb 14 2018
by Molly's 70
I just rubbed some 2 stroke oil on the gasket & put it right together. All seemed well.
Posted: 09:44 pm Feb 14 2018
by bufftester
raygun wrote:I've never understand why 4T and 2T uses a T? If we say 4 stroke why not 4S?
The T is from German: coming from "Takt" meaning stroke, or cycle.
Posted: 01:18 am Feb 15 2018
by B737driver
bufftester wrote:raygun wrote:I've never understand why 4T and 2T uses a T? If we say 4 stroke why not 4S?
Danke schoen...I’ve often wondered the same.
Posted: 10:13 am Mar 26 2018
by BamBam
I am not sure where this 'jet block gasket' sits in the carb. Does anyone have a photo?
I just bought the "All Balls" carb rebuild kit for my '97 KDX 220 from MOTOSPORT and I don't think it came with this 'jet block gasket'.
Should I have any other worries with this carb kit? The needle that came with it is silver colored, and not brass looking. Should I keep factory needle? In forum searches I have seen mentioned that the factory needle is no good, but I don't know that the needle in this kit would be any better (or worse).
Posted: 01:57 pm Mar 26 2018
by John_S
Google "PWK jet block gasket" and click images. It doesn't come in rebuild kits. Jets R Us has them.
If you use the all balls needle start rich like in clip 4 and lean it from there. Who knows how close their tolerances are and we're talking hundredths or thousanths of an inch making a difference in the way the bike runs. I would rather have a genuine Keihin needle like the CEL which is a known good needle for many KDX'ers. If not the CEL, then I would run the stock one.
Jet Block Gasket.
Posted: 02:29 pm Mar 26 2018
by Molly's 70
Like posted earlier, Get the jet block gasket from "jets r us" You have to use a torx bit to get to it. (Torx security 20)? I think.
Jet Block Gasket.
Posted: 08:26 pm Mar 26 2018
by SS109
Posted: 11:19 am Mar 28 2018
by BamBam
Parts on the way! Bought special torx security bits to open it up. Thanks!
Sent from my SM-G900V using Tapatalk
Jet Block Gasket.
Posted: 07:36 pm Mar 28 2018
by SS109
Awesome! I hope it that is the final piece you need to get your KDX running great!
