5.2, 5.4, 5.6 rear susp spring
bultaco4ever
Post by bultaco4ever »
Anyone have a rear shock spring that they don't need? 5.2 or 5.4 or maybe 5.6 would work. The stock spring is a 4.8 and is good for 150 lb riders....I put a 5.0 on from a '97 220 that I used to own.....I'm a big boy....I could use a 5.4.
Re: 5.2, 5.4, 5.6 rear susp spring
What is your weight in full riding gear with all spare tools, parts, water backpack, etc.?
bultaco4ever
290
5.6 or even 5.8.
My '94 has 5.3 @ 235 pounds. ROUGHLY, ROUGHLY 25 pounds per 0.2 Kg.
Don't forget to balance the bike with proper fork springs.
By the way, the stock spring is 4.6 on 1989 - 1994.
4.8 on KDX250 and 5.0 on 1995+.
Different linkage will affect it some, as far as suitability.
Dave B
Post by Dave B »
I have a 5.4, it came installed on my 220 when I bought it, too much spring for me. Located in Ontario Canada.
IceCold4x4
Post by IceCold4x4 »
I snagged a 5.8 spring from a 09 klx250t. Got the whole shock for 50 bucks on ebay. I'm. 270 and it's borderline according to. Racetech I. Need a 6.2
Sent from my SM-N950U using Tapatalk
1997 KDX 200 - FMF pipe and silencer and I have no clue what else yet.
2000 ZRX1100 - 1109 big bore, ZX11 carbs / cams/ double valve springs / igntion box / Kerker exhaust. It's Mad Max black and fast but rarely clean
2006 Volvo XC90 V8 - The toy hauler and sleeper. 300hp and AWD in a soccer mom SUV.
IceCold4x4 wrote:I snagged a 5.8 spring from a 09 klx250t. Got the whole shock for 50 bucks on ebay. I'm. 270 and it's borderline according to. Racetech I. Need a 6.2
Did you check your sag numbers? That is going to tell you if a spring is too soft or too stiff. I can't see a 6.2 being correct. He has a 1989 - 1994 model, if you missed it, as we are in the "KDX 200 E series" subforum. Shock spring rate requirements are a little different on the 1995+ models.
IceCold4x4
Whoops yup missed the e series part.
bultaco4ever
Yeah, i want that 5.4kg spring. I tried sending you a message. Did you get it?
bultaco4ever
Hey, DaveB.....I'm Clint (bultaco4ever).....I could use that spring....text me 224 324 2026
