Tried searching forum with no real luck.
I have set of KLX300 forks and triples, but am trying to find information on what year KX top clamp will work with the klx stem and lowers.
The reason why is I want to be able to have adjustable handlebar clamps. I don't like the fixed 7/8th bar clamps on KLX clamp.
Thanks Sean
KLX top clamp to KX ???
slidinleft
- Has thanked: 49 times
- Been thanked: 15 times
Re: KLX top clamp to KX ???
Hi. Look on KLX Planet if that site is still around. I think it is 1992 - 1995 KX250. I am just not sure on the offset. I know that a whole set with stem swap would work. but I can't remember if the offset is different. I know it changed from 1991 to 1992 KX.
KX125 in those years was solid mounts until 2002 when KX125 got bar mounts finally.
