2009 kx 250f
89kdx200
2009 kx 250f
Post by 89kdx200 »
So i have a 96 KDX and was thinking about upgrading forks and shocks until I found a 2009 kx250 with a blown engine. Now I think the best option would be to swap my 200 into the 09 chassis. What's the consensus on that frame for trail riding? Or is the older steel frame the best?
Has thanked: 52 times
Been thanked: 18 times
Re: 2009 kx 250f
I think one difference is welding aluminum instead of steel.
Re: 2009 kx 250f
Sure as heck tempting. Know anyone with a KXF you could ride? FWIW I have a friend with a KX450F who loves it in the woods. Also see quite a lot of them at hare scrambles and some at enduros.
Yeahthebikes94
Country: NZ
Re: 2009 kx 250f
Post by Yeahthebikes94 »
Would love to see this build! Havent seen many kdx hybrids in a more modern frame than 2005.
As far as AF and SF are concerned, Af tends to be stiffer, and generally slightly lighter. Sf has a bit more flex which some riders like for the trails.
Welding Af is different to steel as you are probably aware.
Please go ahead with this build, Im sure itl be awesome
89kdx200
2009 kx 250f
Post by 89kdx200 »
Awesome thanks for the input. If the bike turns out to be clean I'll be buying it for sure. Aluminum welding and fab won't be an issue. I'll keep you guys posted.
Re: 2009 kx 250f
Did you see where a new cradle has to be welded in due to the pipe exit from the engine? Someone correct me if I am wrong on that. Sorry if you are a master craftsman. Most of us are not, but a few have bought first, thought long and hard about it second.
89kdx200
2009 kx 250f
Post by 89kdx200 »
Ya I know the main tube is is to low and will need to be moved up at least 4 inches. That stuff isn't to big of a deal it's kinda what I do.
Re: 2009 kx 250f
The aluminum frame has been done on here IIRC, and certainly is in the realm of possibility. Would make for a very nice trail bike.
Tyl3r
Re: 2009 kx 250f
Post by Tyl3r »
The aluminum fab work kept me from wanting to use a newer aluminum frame for my hybrid. If you can do the work, I'd love to see the results!
Has thanked: 9 times
Been thanked: 17 times
Re: 2009 kx 250f
I've seen a few nice aluminum frame builds. Mostly around the CRF250, but I imagine the required work here would be similar. Personally I prefer a steel frame for trails, they are less rigid. That's strictly personal preference, obviously. The aluminum frames sure are pretty!
89kdx200
2009 kx 250f
Post by 89kdx200 »
So i checked the VIN on the bike, its currently reported as stolen. oh well.
89kdx200
2009 kx 250f
Post by 89kdx200 »
I found another bike local with a blown engine. Its a 2007 YZF250. Any one have any info on major issues fitting In my 96 KDX engine.
The big ones will be the swing arm width and exhaust but i dont feel that it will be that different?? input??
89kdx200
2009 kx 250f
Post by 89kdx200 »
Picked up a new project bike yesterday. 2007 Kx250f
[url=http://s1328.photobucket.com/user/ls1ve ... f.png.html]Image[/url
EDITED by Jason to show picture. I can't see it on my laptop. I had to go fiddle around and dig it out from photobucket on some link copy and paste.
Re: 2009 kx 250f
Congratulations. Good luck on the work.
89kdx200
2009 kx 250f
Post by 89kdx200 »
Tyl3r
Re: 2009 kx 250f
Post by Tyl3r »
Those last two pictures are what scare me the most! haha Looks good, that thing is going to be sweet. Are you doing all of the aluminum fabricating and welding yourself?
89kdx200
2009 kx 250f
Post by 89kdx200 »
Ya I'll be making up the mounts tomorrow and then on to welding. I'll also need to add approx 1" to the pipe to get it into the engine just right. Then onto wiring.
Re: 2009 kx 250f
Adding an inch to the pipe will sacrifice a bit of your top end, but you'll get some of that back in torque. An inch is a long way in 2 stroke pipes.
Tyl3r
Re: 2009 kx 250f
Post by Tyl3r »
Nice man, keep us posted on the progress!
Timtee
Re: 2009 kx 250f
Post by Timtee »
Definitely interested in how the airbox/boot plays out.
