The '95 KDX200 needs a new clutch. I know you're supposed to soak clutch disks in oil overnight before you install them, but I run ATF type F in my bike. So, my question is, do I need to soak them in ATF overnight or should I just soak them in normal motor oil? Thanks for your time.
Sent from my ONE A2005 using Tapatalk
Soak Clutch Disks in ATF?
Always soak them in the type of oil you plan to run which, in your case, that would be ATF.
Re: Soak Clutch Disks in ATF?
Okay, thanks guys
