antifreeze
Posted: 09:13 pm May 24 2017
by manny
can you use regular prestone coolent
Re: antifreeze
Posted: 09:14 pm May 24 2017
by Friedom
As long as it's aluminum safe, I use whatever is on the shelf.
Sent from my SM-G930V using Tapatalk
antifreeze
Posted: 09:28 pm May 24 2017
by canamfan
If I remember right, your not supposed to use antifreeze that has silicates in it. The silicates wear out the rubber seals prematurely. I'm sure you can google silicates and find out more then I could explain.
Re: antifreeze
Posted: 09:37 pm May 24 2017
by manny
antifreeze
Posted: 12:55 am May 25 2017
by thirdgenlxi
If you want a very good off the shelf antifreeze, go to any Honda or Acura dealership (car) parts dept, and get a gallon of the Honda Type 2 coolant. It's blue..... very much aluminum safe as it has no silicates or borates. Everything stays nice and clean
Re: antifreeze
Posted: 03:44 am Jun 16 2017
by ronjac
I also use Honda coolant. So far I have no issues with it.
Re: antifreeze
Posted: 11:49 am Aug 30 2017
by brademan76
So a 50/50 mix of honda coolant?
Re: antifreeze
Posted: 08:13 pm Aug 30 2017
by thirdgenlxi
brademan76 wrote:So a 50/50 mix of honda coolant?
It depends if it's pre-diluted or not. Some coolants are already pre-mixed 50/50 and you just pour right in, where others are concentrated and you have to mix with distilled water. Its been awhile since I've bought some and I honestly don't remember if the Honda stuff was already mixed or not. Just gotta look when you get it
Re: antifreeze
Posted: 12:32 am Aug 31 2017
by brademan76
I understand that, just wanted to confirm it was 50/50 ratio and not some other goofy ratio. I had a partial jug of genuine honda coolant that I use in my Acura and honda passenger cars (premixed 50%) that I used today to top off my bike coolant.
Re: antifreeze
Posted: 09:00 pm Aug 31 2017
by KDXohio
I use 50/50 yellow Preston and have had 0 problems
