Hi all,
You know how there is an ignition curve where the CDI unit changes the point of ignition? I think as the rpm's increase, the spark advances? What happens if that doesn't occur and stays at a constant point before TDC? I have bought a DIY cdi from an electronic shop because the one my new kdx came with is the wrong one and the new one doesn't have an ignition curve. So will this affect the power?
Ignition curve
Re: Ignition curve
Yes def. And depending on the static number you will have different issues to going from. Hard to start, almost no power, or dangerous detonation.
Sent from my SAMSUNG-SM-N910A using Tapatalk
1997 KDX 200 - FMF pipe and silencer and I have no clue what else yet.
2000 ZRX1100 - 1109 big bore, ZX11 carbs / cams/ double valve springs / igntion box / Kerker exhaust. It's Mad Max black and fast but rarely clean
2006 Volvo XC90 V8 - The toy hauler and sleeper. 300hp and AWD in a soccer mom SUV.
Re: Ignition curve
kwakarider, what country are you in?
- Country: Australia
Ignition curve
I'm in Australia and my kdx seems to have a different ignition system to most models. There is a generator behind the flywheel with 18 smaller coils. On the fly wheel there is a raised patch of metal that moves past an ignition coil. On the old cdi there are no wires for the ignition coil wires wile the new one does.
Ignition curve
"I'm in Australia and my kdx seems to have a different ignition system to most models."kwakarider wrote:I'm in Australia and my kdx seems to have a different ignition system to most models. There is a generator behind the flywheel with 18 smaller coils. On the fly wheel there is a raised patch of metal that moves past an ignition coil. On the old cdi there are no wires for the ignition coil wires wile the new one does.
So, MAYBE
Thanks.
