Loose gasket material in engine
Marylander
Post by Marylander »
Suppose you somehow ended up with some paper base gasket material loose inside the engine (I'm not sure how it happened but it was obviously me who did it). What would you do to clean it out?
knottyrope
Re: Loose gasket material in engine
Post by knottyrope »
in the transmission or the crank area?
if in the crank area, that isn't good and need to tear it down
if in tranny, the paper most likely will get torn up and pulverized
david
Country: UNITED STATES
Post by david »
Has the engine run since the paper fell in there? If it's a single, small piece, you could try compressed air to blow it back out. Or you could stuff paper towel in front of the rod journal and then rotate the crank around, using the paper towel to wipe the bottom of the case out (this works well when you get water in the engine too).
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Yes, which part of the engine?
Marylander
Well, dang, I pretty much already knew I'd be tearing it down. I figured out there was an issue after I rode the bike a little and something felt funny. I'll look again but I'm pretty sure it got in the crank area. The bike has been sitting for a while as I've got other bikes to ride. I'll get on it after I finish up a suspension project on another bike.
Thanks all!
