220 carb boot
Posted: 08:26 pm Mar 26 2017
by patreilly
My 02 220 needs a new carb boot. I bought a cable by Moose. It has a boot that only covers the adjuster nut. Is there a source for just the rubber boot?
220 carb boot
Posted: 10:33 pm Mar 26 2017
by thirdgenlxi
As far as I know, you just have to get an OEM cable to get the right size boot. I got a replacement aftermarket cable for mine and the boot was twice the size around and pretty much useless (and the only reason I was replacing it was due to a cracked boot). My buddy Scott went through 2 (different brand) aftermarket cables on his 06 KX-250 and both also had the same huge boot that mine had. He finally ordered an OEM cable and it fit perfect
Re: 220 carb boot
Posted: 03:49 am Mar 27 2017
piece of bicycle inner tube??
Re: 220 carb boot
Posted: 07:17 am Mar 27 2017
by G22inSC
If you're talking about the small rubber boot at the end of the throttle cable where it enters the top of the carb, then yes, the only way to get the correct size one is OEM. That being said, I'm sure something could be used in it's place such as heat shrink tubing, tape, etc.
220 carb boot
Posted: 04:51 pm Mar 27 2017
by patreilly
OOOOOH G22, Thanks for the suggestion of heat shrink tube. I have just about every size of that stuff. I'm headed for the barn right now.
Pat Reilly
Re: 220 carb boot
Posted: 08:29 am Oct 09 2021
by Clint vB
patreilly wrote: 04:51 pm Mar 27 2017
Pat Reilly
Hi Pat
Were you successful? Could you possibly share a Pic of the outcome? I have the same problem
