Page 1 of 2
wossner
Posted: 03:03 pm Feb 15 2017
by deepwoods
hello, i am looking into getting a wossner piston for my 01 kdx 200,but they come in 66,00, 01,02mm a ,b ,c what to get?my bike has probably 50 to 100 hours on it, thanks
Re: wossner
Posted: 04:15 pm Feb 15 2017
by ced64k
Hi, go to your local shop to have your cylinder measured. A special tool is required.
Re: wossner
Posted: 04:56 pm Feb 15 2017
by deepwoods
does anybody in here have a wossner piston in their 200, and which one , and how is it working out ? and does it come with rings and pin, clips or the bare piston alone? thanks
Re: wossner
Posted: 06:22 pm Feb 15 2017
by bufftester
Stock bore is 66.0 mm. IIRC the difference between the A, B anc C is .01mm so A=66.00, B=66.01 and C=66.02. Get your cylinder measured as mentioned, most mechanics I know just use B pistons (I'm sure it is some old school reasoning involved but idk). I have used them in my jet ski and it came as just a piston, had to rder rings and pin separately, but that was a while ago. Wiseco is well known in the KDX world and what I'd guess most people running non-OEM have installed. I have about 250 hours on my Wiseco with no issues.
Re: wossner
Posted: 10:26 am Feb 16 2017
by deepwoods
thanks, and the odometer on the bike, first digit is? from norway, not used to miles. we use km. i have a odometer that says only miles
Re: wossner
Posted: 04:54 pm Feb 16 2017
by bufftester
1/10 of a mile
Re: wossner
Posted: 05:47 pm Feb 16 2017
by deepwoods
so when it says 336 i have rode 336 miles? it doesn't go further than 999. when its says 010 it means 1 mile?
Re: wossner
Posted: 07:56 pm Feb 16 2017
by bufftester
Is the first digit a diferent color? From what I remember on my original odometer, the rightmost digit was black on a white background and wa tenths of a mile, the other digits to the left were white on a black background and were miles. so 336 would have been 33.6 miles and 010 would be 1 mile.
Re: wossner
Posted: 03:31 pm Feb 17 2017
by deepwoods
yes it looks like that one, it a usa bike, got imported from usa to norway, kan i get a km meter and just replace it with?
Re: wossner
Posted: 07:36 pm Feb 17 2017
by bufftester
Not that I know of, the OEM unit is a direct cable drive. You could replace it with an aftermarket one like a TrailTech. Here in the states it was one of the first things that usually got broken and was too expensive to replace so mot folks I know just never worried about it. Maybe some of the other overseas guys can chime in.
Re: wossner
Posted: 11:38 pm Feb 17 2017
MOVED from "Ask the Moderator" to the general Q&A forum.
If you are asking about getting an OEM Km unit, then I think you can. Check the odometer drive sending unit to make sure the part numbers are the same. There is a gear in there, but hopefully it is the same. The "cable" is technically a square, flexible rod.
Re: wossner
Posted: 05:23 am Feb 19 2017
by deepwoods
only the last digit is white, the 2 in the front are black, so if it says for ex 300 is that 30,0 miles? and one mile is about 1600 meters? or 1,6km?
Re: wossner
Posted: 02:53 pm Feb 19 2017
Yes. The last digit is the tenths.
Re: wossner
Posted: 03:29 pm Feb 21 2017
by deepwoods
thanks jason. but can anyone tell me if the 8093db wossner is a good choice for my 01kdx 200? sound 100 hours.
Re: wossner
Posted: 04:49 pm Feb 21 2017
I have hread several posts from Wossner piston owners saying they thought it was a VERY good piston. I would not avoid it as a choice. I think Namura is the only piston I have heard bad mouthed often.
Re: wossner
Posted: 05:42 pm Feb 21 2017
by ScruffyDroid
I have just replaced the stock piston in my 02 220R with a Wossner. Came with the wrist pin, two rings and circlips. The the UK and Europe, in general, they are more readily available and cheaper than Wiseco.
So far so good. Not heard any bad reports about them.
Re: wossner
Posted: 05:08 pm Feb 22 2017
by deepwoods
thanks jason and scruffy, but do you guys think that since my bike has run about 100 hours the B piston is the right choice? 8093db is the name. last letter indicates the size, even if its bugger all difference in size. if some one who has put the B PISTON WOSSNER in their 200 would chime in it would be great!
Re: wossner
Posted: 05:41 pm Feb 22 2017
by ScruffyDroid
Mine has the A piston in. Standard size.
Re: wossner
Posted: 07:01 pm Feb 22 2017
If you are wanting the piston clearance to match up just right, you are going to have to take the piston and cylinder to a machine shp, motorcyle shop or have high dollar tools yourself.
Re: wossner
Posted: 05:42 am Feb 24 2017
by deepwoods
yeah i know jason, just wanted to bypass the trouble, on a side note , does any one know how much a new kdx 200 h cylinder costs?
