1990 kdx 200 "I have another question."
First I am going to post pictures until the moderator jason can see my photos.
Re: 1990 kdx 200 "I have another question."
I can see the picture I the second post, but not the first.
It is missing a rear lower chain block. By the way
Been a few months. The bike is coming along very slowly. I ruined my front master cylinder. I broke the tip of an extractor off in the screw. Everything else has gone fairly smooth. I kinda took the tusk train to kdx town. Bars, Levers, clutch perch. I haven't posted much but I have used the forum for information on many occasions. So thank you to those who have documented their work. So here are my new questions. #1 Is their an acceptable after market master cylinder, or should I buy a used one and a rebuild kit? #2 Does anyone know the specs on the front brake caliper bolts? Or, does anyone know of a rebuild kit that comes with new front caliper bolts? I will post pictures soon. I'll open a photo bucket and get it together soon.
Welcome back.
I would look for a use one. It might not need rebuilding. It may work well enough.
socket bolt, 8 mm x 20 mm (would be 8 x 1.25 mm threads in my guesstimation)
From Partzilla:
From Partzilla:
Thank you jason. I found bolts this morning at the local hardware . just as you said 8 x 20. They were also in my kawasaki spec bolt. In my defense my kawasaki spec bolt has turned into kawasaki all the bolts. Hardware stores have labels, I kinda fake it till ya make it. The grind goes on. I find myself buying a lot of tools with this bike as well. Im excited to ride it. Once I finish the front brake and seat. Its test ride time. It doesnt look a whole lot different. Ill get pictures up asap.
My new question is about handlebars. I bought the standard tusk handlebars and feel they are a bit wide. Is their any disadvantage to shortening them by about an inch a side? I grew up riding bmx and used to cut my bars down to like hand grips size. I plan to ride it first regardless.
Read up on cutting down handlebars. Unless you are really riding super tight gaps between trees, I would not shorten then too much.
- Country: UNITED STATES
Your hands will tell you how wide you need them. You just have to pay attention to them. If you are getting blisters on your first thumb knuckle, that means the bars are too wide and your body is more comfortable with a narrower grip. I cut my bars about 1/2" on each side.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
A few pics of what ive been up to.
Any suggestions on front head lights? I wont be rewinding the stator till winter. So I need something the bike can power from stock. Im also not in love with the stock head light. Do any of you find yourself actually needing a head light? Is their anything else I could do with the wiring? I kinda keep thinking about putting an oscillating l e d light on the front end. Think the KDX version of kitt from knight rider.
I picked up a cheap Chinese rectifier for like $10 on eBay, wired it in and installed a 25w LED light bar above a number plate and led tail light. Looks pretty slick.
What brand are the fenders?
UFO so far im really happy with them. I bought the recomended chain from rocky mountain. Im fairly sure its too short. Its a 110 looks like I will need a few more links. I shoulda known to just buy big and cut to size.
110 is correct for stock sprocket size.
Its alive!!!!!! I am still waiting on a seat cover and need to figure out my head light situation. But it rode around the yard and shifted into third today. "Jason" You are probably the only one that cares. Thanks for being there for me kdx jedi. Ill get pics up later tonight.
Thanks. I think there are several here that are helpful. No problems there.
I am glad you have it going. What happened with the chain? Stock sprocket sizes?
I switched to a 12 front and a 47 rear. Seems to lug around pretty well. I didnt really put it through the paces. Ran well. Little bit of a stumble. "I would feel a bit robbed if I didnt have to mess with the carb a little bit. I am pretty excited.
LOL! If you had no carb troubles, you would not be normal.
So the 110 did work?
