Where can I find maximum spring lengths?
I have a 2002 Kdx 220 and am replacing all linkage bearings and having shock rebuilt. To complete the package I will replace spring if necessary. Where can I find spring tolerances information?
Re: Where can I find maximum spring lengths?
Maximum?
It will shorten as it wears. Minimum length is given.
You may need to get the info from a service manual. I don't have mine handy to look it up
You are correct, minimum. I bought the manual this site recommends. It does not say minimum acceptable length for the rear spring.Jason wrote:Maximum?
Do you have any other suggestions?
Can someone please look in his service manual and post up what it says? I don't have mine worth me. I am out of town. Thanks.
Thank you. I have put a lot of effort into trying to find this information with no luck. My next step is to call Kawasaki once the local dealer opens for business.Jason wrote:Can someone please look in his service manual and post up what it says? I don't have mine worth me. I am out of town. Thanks.
Rear spring: Std length 255 mm. Service limit: 250 mm.
Front fork spring: Std length 457.5mm. Service limit: 448 mm.
Thank you sir! For my curiosity and maybe the curiosity of others, where did you find this?pumpguy wrote:Rear spring: Std length 255 mm. Service limit: 250 mm.
Thank you, pump guy.
It is in the factory service manual.
Okay thanks. Disappointing that the Cyclepedia manual does not share that information. As much as I love that manual so far I found it does not include a few details like this.Jason wrote:Thank you, pump guy.
