is this the best place to get power for trail tech vapor
Posted: 07:29 pm Jan 01 2017
by two-stroke-brit
Hi All, i read that to get power for the trail tech you can tap into the headlight supply but is that the best solution?.
i am mechanically proficient but electrically challenged.
i didn't install the three way switch (dont know if it works or what it does if anything)
all help is much appreciated .
T I A Mark.
Posted: 11:59 pm Jan 01 2017
by thirdgenlxi
You can run it off the headlight supply, BUT, the headlight has to be on or the tach will do all kinds of crazy stuff. It doesn't like the direct AC power with no load on it, for some reason. But if the headlight is on it should be fine
Re: is this the best place to get power for trail tech vapor
Posted: 11:00 am Jan 02 2017
by two-stroke-brit
Thanks third gen .
so if not the headlight where is the next best place so i dont need the head light on.
thanks mark
Posted: 12:39 pm Jan 02 2017
by Julien D
My guess would be right into the 12v output from the VR.
Posted: 12:52 pm Jan 02 2017
by spl383
that is were i connected mine. I pulled apart the connector to the yellow wire, and put the red power wire from the trail tech in there then put the connector back on. The tach is a little off but i don't look at the tach anyway.
Posted: 12:59 pm Jan 02 2017
by spl383
put the red wire from the trail tech here.
Posted: 05:08 pm Jan 02 2017
by two-stroke-brit
EXCELENT advise as i hoped .
thanks gang , i do need leading by the nose when it comes to sparky stuff.
cheers and happy new year.
Mark
Posted: 09:02 pm Jan 02 2017
by two-stroke-brit
well partial success,
the water temp Gage is not reading
and without the lights on the revs are double-ish.
but overall happy so far ( no fires ) .
the temp thing is weird as i used the same ground point for both power and temp ???.
I plan on moving the power supply to the VR and checking the earth.
i think i read that the shift lights dont work if only battery on internal power so the power and earth should be good ...
again any sugestions are truly welcomed.
Thanks mark
Posted: 12:19 pm Jan 03 2017
by IDRIDR
two-stroke-brit wrote:well partial success,
Thanks mark
Reset the Vapor by pushing and holding the little reset button on the back. I've installed two and both times the temp didn't work until doing a reset.
Posted: 07:31 pm Jan 03 2017
by two-stroke-brit
Thanks IDRIR i tried the reset and it worked after a little while.
would the power be more stable from this yellow wire ?
thanks all.
mark
PS also what is a good number for the temp range ,now it works .
i thought 180F as a high and 220F as a danger level.
what say you.
mark
Posted: 01:42 pm Jan 04 2017
by IDRIDR
two-stroke-brit wrote:Thanks IDRIR i tried the reset and it worked after a little while.
thanks all.
mark
what say you.
mark
Good to hear you have temp working.
I'm not sure about power.
I think your settings are a good starting point. I've not had mine on the KDX long enough to get a feel for it. On my '06 KLX250, the stock over-temp warning lights up between 225 to 235. I set the vapor to trigger at 210 (warning) and 215 (danger). The warning started at 195, and I kept bumping it up because it was lighting too soon.
Posted: 09:44 am Jan 05 2017
by two-stroke-brit
i don't know if it is OEM but my bike has what looks like 4 x 9v battery's tapped together and cable tied to the handle bars.
would taking the power from one of the wires from this bundle be a more stable power supply ?
but then would the backlight stay on all the time and flaten the battery?
T I A Mark
Posted: 10:43 am Jan 05 2017
by IDRIDR
The battery doesn't sound stock. It may provide a more stable power supply.
The vapor senses when the bike has stopped and shuts down the backlight after ten minutes +/-.
Posted: 12:12 pm Jan 05 2017
by Tyl3r
That yellow wire that you showed above, comes directly from the stator. It needs to go through a regulator/rectifier before you can tie into it. Maybe try tracing the head light switch power wire back to see what it connects to, then tie into the same point?
If I were you, I wouldn't trust the battery pack thing that you were talking about, especially if you don't know where it came from, how to charge it, what the output is, etc...
I know this from putting a BD dual sport kit on my bike. When I did, I ditched the stock regulator and rectifier and plugged in the BD harness right at that connection. The BD kit comes with its own regulator and rectifier to power everything. They even leave you an open power connection to tie the speedo into... super slick if you ever wanted to go down that road.
Posted: 04:12 pm Jan 07 2017
by two-stroke-brit
this were the wires go to the voltage regulator.
a brown and a black/yellow.
and there is an inline plug which would a good place to take the power from .
which color wire should i use .
Thanks Mark
Posted: 07:04 am Jan 12 2017
by two-stroke-brit
Many thanks to all that helped but i was unable to find a stable power supply for the vapor and will just have to run with the lights on.
cheers mark
