pipe install
- Country: japan
pipe install
Do i need the copper washer between the pipe and cylinder mine melted,should i seal the pipe and head some how used high temp silicone in the past thanks wes.2003 kdx200
Re: pipe install
The copper washer helps to prevent the pipe from damaging the aluminum head. Are you using the O-rings as well?
Chris
2001 KDX 220R
2001 KDX 220R
- doctord23
Re: pipe install
Yes you should install the copper rush washer and the o-rings.
You don't need to seal beyond that unless you have damage to the opening in the head.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
Re: pipe install
Steel wins against aluminum. The washer helps protect the cylinder from wear from the pipe end. Get a new one.
