crank bearing removal questio
Posted: 05:05 pm Dec 06 2016
by argclh6670
hey guys... I'm working on my 92 KDX250 hybrid, changing the crank seals, bearings. ive removed the crank and one bearing stayed on crank....how do i remove that off the crank? special tool or is there a way to improvise? thanks in advance
Re: crank bearing removal questio
Posted: 05:36 pm Dec 06 2016
by Tedh98
I use the cheap bearing pullers from Harbor Freight. They are plenty strong for getting the bearing off the crank.
I have also used them for a number of other tasks, making them an even better bargain.
Posted: 08:15 pm Dec 06 2016
by argclh6670
Tedh98 wrote:I use the cheap bearing pullers from Harbor Freight. They are plenty strong for getting the bearing off the crank.
yeah....i just ordered one. figured its a good tool to have around. thanks for reply.
Posted: 08:14 am Dec 07 2016
by Julien D
Stick it in the freezer for a few hours, then into a 250 degree oven. The bearing should slip right off.
Posted: 05:21 pm Dec 07 2016
by argclh6670
Julien D wrote:Stick it in the freezer for a few hours, then into a 250 degree oven. The bearing should slip right off.
good idea ...i have the puller coming from online...notsure i wanna wait till it gets here. i think I'll try ur suggestion.
