? 220 carburetor ?
Posted: 12:34 pm Feb 08 2006
by kdxquebec
Hi friends.
Again a will fit or not question
Are the 2001 220 stock carbs and 2005 220 stock carbs are identical?
Will the 2001 needle/slide/screw cap and cable will fit in a 2005 carb?
thanks a bunch (just to be sure before we buy)
phil
Posted: 01:43 pm Feb 08 2006
by GS
Phil, not sure of the answer but try referencing / comparing part numbers at:
http://www.kawasaki.com/Default.asp?str ... intParts=1
Greg
Posted: 01:50 pm Feb 08 2006
by m0rie
Phil - They should be the same.
Posted: 06:39 pm Feb 08 2006
by kdxquebec
Thanks Gs/m0rie...
Buykawasaki.com? what a great idea!!
They have the same assy part number so I suppose they are identical.
Posted: 11:37 am Feb 09 2006
by canyncarvr
If you're buying a used carb..at the very least know the jetting is going to be way off. Just assume it to be.
Be careful. Lots of things can be wrong that you won't know 'til after you get it. Unless you're after something in particular...try to determine (at least ask) that it has not been modified in any way. I've read of folks taking a dremel to their slide to modify the cut. Maybe that works sometimes..but I'd sure be leery of a carb modified in someones garage.
Other than that...I'm sure it will work out perfectly!!!
Posted: 07:27 am Feb 10 2006
by kdxquebec
I will confirm with the seller
Thanks
This is a long story...My friend need an other carburetor because his mother lost his carb.The carb was in a grocery plastic bag and she lost it.
Advice of the day
Never leave your carb to your mother.
Posted: 09:26 am Feb 10 2006
by Colorado Mike
Look in the laundry room, should be hanging on the door knob. That's where my mom put everything she didn't know what to do with.
