Hi guys,
I realize that this is an older thread, and that a decision has already been made, but for people who may be looking into it in the future, I have some input on the 225 kit from Eric.
When I had the mods done, I requested that the bike run on pump gas. IMHO it does exactly as it should. I requested something on the order of mo better porting, but kind of biased toward the mid and top, so I'm not sure exactly which description it actually falls under. It does, however, chug very well right off the bottom, hits hard in the midrange, and revs much higher than stock. I use a Pro Circuit 'Works' pipe and MT DFII reedcage. I normally ride at about 1000-1700 feet of elevation. I have not measured static compression, nor have I measured port timing.
I have the bike jetted crisply, and it runs very well.
I have never experienced audible detonation under any type of acceleration. I do sometimes hear what I assume is mild detonation during sustained operation at higher vehicle speed and RPM with constant or slightly trailing throttle (letting off) around mid-throttle postions. It does not occur at wide open throttle. The only time this occurs is when I'm riding in 'desert style' conditions - very fast in upper gears for a very long time and the motor getting pretty hot. I have not noticed it when riding at lower speeds or on anything resembling a trail that requires actually slowing down.
I'm pretty sure what is happening in my case is just a result of a problem inherent to the type of carbs used on dirtbikes - when operating at high speed (ground and RPM) and slightly letting off the throttle, you can get into an excessively lean condition. People have burned up well-jetted stock bikes from the same type of situation.
IMO and experience, Eric can build a 225 to run on pump gas - though it is possible that he might not get it exactly right the first time based on the specifics of your situation (i.e. he may need to cut the head again to a more conservative configuration). Again IMO, I think Eric probably builds engines to get the best possible performance from the package - in this case, this may mean head geometries that are on the borderline of acceptability for pump gas, especially given the wide variations in quality and makeup of pump fuels.
Dang it I get long winded.
