2002 KDX200 - Q Stealth?
Posted: 10:05 am Nov 02 2016
by TeamDoty
Hey everyone,
I'd like to install an FMF Q Stealth onto my 2002 KDX200 (h8?). Problem is, FMF doesn't list a model specific to my applications. I've emailed their customer service requesting a suggested model that might be modified to fit but haven't heard anything back (2-weeks now).
I did a search here and found a rider of a 2001 model that stated he had a Q Stealth on his bike so that should work for mine, I just don't know what model to order:
http://www.kdxrider.net/forums/viewtopi ... th#p127091
Can anyone help me identify the model I should be looking for? I'm going to message that member and see if they can find a model number on their pipe (if they still have it... it's been a couple years since that post).
Thanks for any help!
Heath
TeamDoty
Re: 2002 KDX200 - Q Stealth?
Posted: 10:20 am Nov 02 2016
There is no Q Stealth for a KDX. The one in the other thread is a normal Q. Perhaps the poster used the wrong name.
Posted: 01:54 pm Nov 02 2016
by TeamDoty
Appreciate it!
Yeah, I'm thinking I might have to try to see one on a bike and try and figure out if there's a model that could be modified to fit.
Posted: 05:21 pm Nov 02 2016
by G22inSC
Anything can be modded to work, just depends on how far you want to go. You could probably take any Q Stealth silencer and cut the mounts and pipe off. Then you would need to weld on KDX mounts and a KDX pipe. Unless you've got some welding skills and extra parts laying around, you're going to spend more than you would like.
Posted: 09:29 pm Nov 02 2016
Keep in mind the diameter of the cannister and such. They are really big.
Posted: 12:27 am Nov 03 2016
by bufftester
Do you really need a Q Stealth? I run a Turbinecore 2 and it is not much louder than my buddies KTM with a stealth, and it has passed every Forest Service sound check with no issues.
Posted: 11:17 am Nov 03 2016
by TeamDoty
bufftester wrote:Do you really need a Q Stealth? I run a Turbinecore 2 and it is not much louder than my buddies KTM with a stealth, and it has passed every Forest Service sound check with no issues.
Thank you... not sure if I "need" a Q Stealth - so very good point... and I really should have been more clear. I'm really just trying to get this machine as quiet as possible.
My buddy is a semi-pro mx'er... and he has his own practice track. Problem is, there's some homes nearby and we do everything we can to keep the noise and the dust to a minimum to avoid becoming bad neighbors.
So my real goal is to quiet the bike down as much as possible - I'm not too worried about losing some performance, this thing has way more performance than I'll ever be able to handle!
Thanks for the advice on the Turbinecore 2... I may look into that or look at possibly going back to stock.
THANKS!!!!
Posted: 04:06 pm Nov 03 2016
by bufftester
No worries, if your buddy runs a 4T at his track no one will even know you're there lol
Posted: 11:13 pm Nov 03 2016
Research your options. The Q may be quiet than the standard Turbine Core 2.
DB Snorkel still around?
Exhaust pipe wrap?
Lid on airbox?
Posted: 04:07 pm Nov 07 2016
by TeamDoty
Thanks everyone! Those are all good ideas to look further into - I really appreciate it! I've even been hunting down stock pipes and silencers on fleabay. I was looking at the Q Stealth for the KX250 (the 2-stroke model) and visually... visually... they look very similar in geometry to the powercore 2 I have. My guess is that these are very similar in shape/proportion/dimension - might be worth a shot because it's crazy how much peeps want for their old oem stuff on fleabay :)
Posted: 11:09 pm Nov 26 2016
by Ffryno13
You have to move the mounts to use the kx250 and make a bushing for tge bell end to make everything right it's about a 1/16" to big. I tried a Kx 250 tc2 on hybrid but went with the moded kdx and sold the Kx tc2
