fiber reeds vs. carbon reeds
bws2
Post by bws2 »
I'm looking at new reeds for my 2001 KDX200
I see Boyesen has the Superstock fiber reeds and Superstock carbon reeds.
Are the carbon reeds worth the extra money or should I stick with fiber?
cornishwrecker220
Post by cornishwrecker220 »
Either are good..... It all depends on your budget .
I'd say the carbon reeds would be a better option for various reasons longevity being just one.... Performance being the other.
firsthere
Post by firsthere »
I'm not sure which is better but i just installed the power reeds and noticed a little better response and more top end (running stock pipe) Had to go richer on the main and lean the pilot so maybe look at jets also. Your results may vary.
sarrant
Post by sarrant »
bws2 wrote:I'm looking at new reeds for my 2001 KDX200
Why not Power Reeds?
KDXohio
Re: fiber reeds vs. carbon reeds
Post by KDXohio »
Get the rad valve! :supz:
bws2
Post by bws2 »
I didn't see them listed at Rockymtn, but I'll do a search for them.
Do you think they'd be better than the super stock ones?
bws2
Post by bws2 »
KDXohio wrote:Get the rad valve! :supz:
I kind of wanted to stick with the stock reed cage.
firsthere
Post by firsthere »
Yeah, I had to go to Motorsports Outlet to get the Power Reeds. Don't forget jets if you don't have some already. Mine likes 40/155 @ 3500'+ all stock except w/PR.
Oh, and they don't come with a cage gasket. If you are careful reuse the original with some sealer.
