1). Feels like the front tire has no traction, wants to push, and has to be forced to initiate the turn.
2). Once I get it to finally turn it immediately wants to under-steer and low side if I do not quickly get on the gas.
It is either doing one or the other and has a very very small sweet spot in between where turning feels predictable and comfortable.
Things I know that may be causing this. Tires are 10 years old and the rubber is probably junk. The compression is way too stiff. Forks may need to have the air bled, and the oil changed, the fork tubes could be slid up for a steeper rake. Sag needs to be set? And I could drop 35lbs of cg in my belly?
I am very curious if any of you also experience this? I once had an 05 250F that I track rode and remember this feeling. I was never able to get rid of it. Love your ideas and opinions please?
Ok, gonna go pressure wash last weekend off of it.
Thanks for your opinions guys.
