head set pin removal
Posted: 12:47 pm Oct 21 2016
by javjacob
I pulled my carb and head so I can send them to RB to be worked over. RB says to remove the set pins on the head, I removed one without much trouble but the other one is stuck and I cant get it out. Is there a trick to getting it out?
Re: head set pin removal
Posted: 12:55 pm Oct 21 2016
Washer around it, pliers to pull it has worked for some
Posted: 01:30 pm Oct 21 2016
by javjacob
I will try it some more. I have tried needle nose vise grips and still haven't got it to budge.
Posted: 02:04 pm Oct 21 2016
by pumpguy
You might try some heat around the pin, not on it. While it's hot, spray on some penetrating oil.
Good luck with this.
Posted: 03:36 pm Oct 21 2016
by bufftester
+1 heat and oil
