head set pin removal
I pulled my carb and head so I can send them to RB to be worked over. RB says to remove the set pins on the head, I removed one without much trouble but the other one is stuck and I cant get it out. Is there a trick to getting it out?
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
- Has thanked: 5 times
Re: head set pin removal
Washer around it, pliers to pull it has worked for some
I will try it some more. I have tried needle nose vise grips and still haven't got it to budge.
You might try some heat around the pin, not on it. While it's hot, spray on some penetrating oil.
Good luck with this.
