2003 kdx200 on a 2004 kx250 frame
mliz
Post by mliz »
Hi,
I recently traded my klx250 for this flawless kx-dx hybrid minus the chamber which was dented and punctured in multiple places due to someone not knowing what they were doing trying to make it fit. Everything checks out but I am still unable to get it running right.
Here is what I am running:
FMF Gnarly Pipe (New rubber and copper gasket and springs)
FMF PowerCore 2 Silencer (Brand new packing)
35mm Keihin PWK (stock for kdx200 h models)
Stock KX250 Airbox (Clean and oiled filter)
I have eliminated every problem so now it has to be the carb. I have rebuilt the carb with new pilot and main jets, float bowl gasket, idle screw, mixture screw, jet block gasket, new needle, and cleaned it thoroughly with carb cleaner and a guitar string. Also, took everything back apart after first unsuccessful try to get it running to make sure everything was as/where it should be.
I rejetted to what FMF suggested (155/48) and no luck. Ran the idle screw all the way in and still no luck. Dropped the pilot down to a 35 and still too rich. The only way I can get it to idle is by using the throttle adjuster to bring the slide up high enough to let it breathe which I know is NOT the way you want to set your idle. Also, every time I pull my carb it is wet with gas on the intake side. I am thinking something is worn out internally (whatever the PO soaked it in was some nasty stuff, jet block o-ring was almost completely not there) but before I drop $200+ on a new carb I was wondering if anyone has had similar problems? Or have any ideas what is going on because I am out of ideas.
Thanks,
-Matt
royadams
Re: 2003 kdx200 on a 2004 kx250 frame
Post by royadams »
Low speed screw all the way in is richer. How is compression, reeds, crank seals. The jet block gasket can also be tricky to get seated.
mliz
Post by mliz »
Mixture screw is 1.5 turns out and it does not matter where it is set at, since I have to bring the slide so high to get it to idle.
Reeds are flawless.
Countershaft seal was replaced but not sure about crankshaft seal. It is not drawing oil up and oil level in trans is constant so I think those are good.
Have not checked compression but looked in cylinder and it looks perfect.
Jet block gasket is seated correctly, made sure of that when I took the carb fully apart 3 times.
Tedh98
Post by Tedh98 »
How did the PO get the carb to mate up with the 250 airboot?
mliz
Post by mliz »
It fits perfect so really not sure if he did anything special.
G22inSC
Post by G22inSC »
Maybe due to minor differences between a 125 and 250 frame? Just guessing.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
mliz
Post by mliz »
G22inSC wrote:Maybe due to minor differences between a 125 and 250 frame? Just guessing.
Pretty sure it is due to a shorter airboot from the air box to the carb. At least that is what I read in another thread.
JL4049
Post by JL4049 »
If it's soaked with fuel on the intake side, and it's not float level related, chances are your reed valves are stuffed although you checked these. How well are the reeds centred on the plate? If they are off to the side a bit, the edge can catch in the housing and hold open a bit.
mliz
Post by mliz »
So it has been a while since I posted but some bottom end work was done. Engine got new crank bearings, a new governor lever (what opens the kips), cylinder got a light hone with new rings, clutch basket got a smoothing out, and everything I could possibly check, got inspected per the manual
mliz
Post by mliz »
Everything was in spec and looked great. Valves look good but now I am thinking it must be the float. The carb seals when at the exact right spot with I take the bowl off and blow through the inlet tube. The carb has been fully rebuilt but still no luck. The carb is very rough and looks like it has been soaked in some crazy strong solution since some of the metal is pretty worn. Sourced a new carb and should be here soon. I will post again when I get the new carb. Hopefully it fixes all my problems.
Goofs luck with it.
Kxrob
Post by Kxrob »
Might be a bit late , but is the carb sealing around seal of air metering block
mliz
Post by mliz »
New carb is on and it is running nicely. Need to still perfect the jetting but since it still pretty cold here, I am going to wait until we have a 60+ degree day.
mliz
Post by mliz »
The carb was all sealed up. Had it running and sprayed some carb clean on the rubber boots and where reed boot connects to the motor. No rise in RPMs so I am thinking I have a good seal.
