Air box/ snorkel tips?
Posted: 09:19 pm Oct 15 2016
by Moebraap
Anyone have any tips on How to take out the air box. ?Trying to put this carb in single handedly can be a real b**** haha
Posted: 09:30 pm Oct 15 2016
by canamfan
Remove the subframe piece that bolts on and it will come out the side. H series If your just installing the carb hold it up in position, install the slide and tighten the cap push the back of the carb into the airbox boot enough that the front clears the intake boot, then push the carb over and slide it into the intake. If the airbox boot is not as flexible as it once was, you can tighten the clamp on the back of the carb before you pull it into the intake side. That way the carb won't pull out of the airbox boot.
Re: Air box/ snorkel tips?
Posted: 11:56 pm Oct 15 2016
by Moebraap
Posted: 03:59 am Oct 16 2016
E
Posted: 07:39 am Oct 17 2016
by Moebraap
Im having a problem finding them subframe bolts for the airbox. Can youhelp
Posted: 09:59 am Oct 17 2016
It is a sub pipe, not really a sub frame. It is the left rear frame bar that bolts in / out.
Posted: 12:13 pm Oct 17 2016
by Moebraap
Do you mind sending me pictures?im lost buddy. I appreciate you helping me out!
Posted: 12:36 pm Oct 17 2016
the bar that the coolant tank mounts on, about 1.5 feet long
Posted: 04:09 pm Oct 21 2016
by bufftester
This is where having a service manual pays for itself.
Posted: 10:23 pm Oct 21 2016
by Dekon
Look at the third and fourth pictures, the sub bar is removed in picture three and installed with the air box in picture 4.
http://www.kdxrider.net/forums/viewtopi ... 03&t=14595
Also looking at the picture you linked, it is a good idea to route the front brake line to the inside of the fork, catch it on a branch or something else in the woods and you'll more then likely tear it off.
Posted: 06:37 pm Oct 22 2016
by Moebraap
Thanks
