Who makes a hub cap delete for the mileage gauge?
Willbilly
Post by Willbilly »
I saw it posted once and am not having any luck finding it again.
I'm looking for the aluminum hub cap delete that eliminates the mileage gauge.
Thanks
Re: Who makes a hub cap delete for the mileage gauge?
Zip Ty Racing used to make one. You may want to call them.
Tyl3r
Post by Tyl3r »
I guess I'll share this haha it says its the last one. I was thinking about buying it, but probably won't.
http://www.ebay.com/itm/262187522167?_t ... .S1.R1.TR1
Only one I could find anywhere!
Willbilly
Post by Willbilly »
Thanks guys. I'm not looking for a cap to the existing spacer. I'm looking for a spacer replacement.
sarrant
Post by sarrant »
Why? The existing gear housing is already cast and matched to fit that space and protect the seal perfectly. There's no real weight to be saved or anything else with a custom spacer.
Ah, OK.
gravelcruiser
Post by gravelcruiser »
Maybe a little too redneck, but I used black silicone to plug the hole and it works great, is not noticeable, and is removable if you decide to put the odometer back on.
Pipeliner
Post by Pipeliner »
I did the same exact thing with the silicone. I stuffed a rag in first then sealed it up. Works great!
