Replacement Flywheel - CDI - Coil
torgo
Post by torgo »
Well I have an 1980 KDX 175 I am trying to restore to do some vintage racing. Like a lot of these older bikes the magnets on the flywheel have come off. After some extensive internet searching I found a place in Germany that makes a complete kit to replace the flywheel, CDI and coil all the while adding a charging coil and regulator/rectifer to get 100W DC.
https://www.powerdynamo-shop.com/shop/s ... cts_id=939
Has anyone heard or used one of these kits? With the exchange rate it looks like it will run me about $300. For that you get the flywheel, CDI, Coil, Reg/Rectifer.
I don't think that is too bad since the flywheels are Unobtainium and the available CDI are all used.
Comments?
Thx
Sorry honey it was an impluse buy.
Re: Replacement Flywheel - CDI - Coil
Surely that stator with all those coils is not the correct one, is it?
The lower left piece says Czech Republic.
torgo
Post by torgo »
I emailed them and asked if it will fit the USA bike. What it looks like is that it fits the SR model. I'll keep you posted.
jeswinehart
Post by jeswinehart »
How bad is your flywheel magnets Torgo ? Can you post up pics of them please ?
I rework Kawasaki flywheels. Mostly Tecate but have done other models too.
john
torgo
Post by torgo »
I don't have any pictures (until tomorrow) but two have just come loose and the third has come loose and is broken in half (clean break).
I was thinking they could be reglued and I was going to try it, but I would gladly let someone with experience give it a try.
I have not taken them out of the flywheel so the North/South orientation is still good. I would be happy to send it to you to give it a try.
Worst case I will have to go with the Powerdynamo setup.
jeswinehart
The broken one is useless for sure. Once they break they become 2 magnets each with north + south poles and they will not go back together.
Is your a 4 magnet or 3 magnet type ? If it is the 4 magnet I can definitely be of help.
http://s1122.photobucket.com/user/jeswi ... ort=3&o=47
torgo
Post by torgo »
Well that sucks, mine only has 3 magnets. I don't suppose that you might have a third magnet? Maybe I can see if someone has one. Otherwise I think I am going to look into the PowerDynamo thing.
Thx
jeswinehart
No, I wish I did have a magnet for you,,,, darn it. Yeah, if you can find one I can take care of the rest of reinstalling and encapsulating all of them so ,,, no more loose magnets.
Any replacement magnet you get will need to be the correct polarity or flywheel will not work. I (or you) would just about need a intact one to see what the polarity lay out is. When I ask for pictures I ask the keyway be facing towards top (and visible) just to know what I am looking at.
torgo
Post by torgo »
Here are a few pictures of my flywheel.
Edited
I filed small notches on the rim to mark where the ends of the Magnets were at. I also numbered them and used arrows to indicate how they go back in.
[imgImage][/img]
torgo
Post by torgo »
I edited my post so the pictures work now. I also JB Welded the magnets back in after using my dremel to clean all the rust and old glue off the inside of the flywheel and magnets.
I cleaned up all the connections and am going to put it all back together tomorrow and see what happens. If this doesn't work I am going to give the Powerdyanamo a shot.
Thx
jeswinehart
Any luck Torgo ???
torgo
Post by torgo »
No luck yet, had to work 16 hr shift yesterday. Put it together Sunday afternoon.
torgo
Post by torgo »
I got it back together and i have spark and it is better than before, but still not great.
torgo
Post by torgo »
I have ordered the Powerdynamo unit and will install it as soon as it arrives from Germany. :supz:
torgo
Post by torgo »
Totally amazing. I ordered the Powerdynamo on the 17th and it arrived today the 20th. From Germany to Iowa. I'll be installing it on Saturday. :supz:
WOW!!
mwoj
Post by mwoj »
Let us know how it goes.
torgo
Post by torgo »
I didn't take any pictures, but it was pretty straight forward except the timing. The Powerdynamo flywheel doesn't have a keyway in it so you can time the bike any way you want. The instructions say to refer to your manual for the correct position for ignition timing. The manual I have doesn't list the deg or mm for timing. The new stator has two pickups so I figure that is how they configure the advance. I made a piston stop out of an old spark plug with a 3/8" bolt tapped in it so I could rotate the crank and have it stop exactly where I wanted.
I set static timing to 1.2mm BTDC. The systems comes with a new CDI/Coil combination unit and voltage reg. The new stator puts out 12VDC so I had to change all the bulbs in the tail light and headlight.
Other than that the the bike runs great. It starts first kick warm and 2-3 kicks cold. It idles smooth and it is nice to have 100W for lighting. All in all it works and now I can concentrate on fininshing the rest of the bike.
:partyman:
WOW! Thanks for the report!
