Oil seal vertical governor shaft
Jasper
Country: Belgium
Post by Jasper »
Hello
How do i replace the oil seal of the vertical governor shaft?
Jasper
Country: Belgium
Post by Jasper »
Do i need to take out the clutch basket and remove the right cover so i can remove the shaft or do i just have to take out the little screw and remove the shaft
ohgood
Post by ohgood »
Jasper wrote:Hello
i would gob some rtv on it and ride. no one will ever see it behind the pipe.
if you want to do it right, you'll have to pull the clutch cover, clutch basket, and governor
