E series crank shaft
Posted: 09:23 am Sep 04 2016
by Friedom
Anyone have a decent one around? I've been informed by Ron B that the one I had is not usable or repairable. :/
"Good job, guys. "
Re: E series crank shaft
Posted: 10:10 am Sep 04 2016
UGH. Sorry to hear that.
Posted: 06:17 am Sep 07 2016
by Julien D
Bummer. What year is your bike? They changed the flywheel mount at some point during the E series. Can't recall what year, but the earlier uses a bolt that threads into the flywheel side, the later uses a nut and the crank half on the flywheel side is threaded on the outside. Probably won't matter as long as you get the right bolt/nut to go with.
http://www.ebay.com/itm/1989-Kawasaki-K ... Q3&vxp=mtr
Posted: 09:43 am Sep 17 2016
by Friedom
Mine is a 92.
I've seen that listing a few times now. The end got banged up/distorted, and the surfaces that ride under the seals are pretty corroded too.
There's a 96 on ebay that looks good. From what I've seen it looks like the same crank is on the H series. Anyone able to confirm or deny?
"Good job, guys. "
Posted: 11:46 am Sep 17 2016
Do you mean to have "Good job, guys. " as a signature, but don't know how to do it??
Friedom, any chance you are in north AL?
Posted: 11:50 am Sep 17 2016
by Friedom
Jason wrote:Do you mean to have "Good job, guys. " as a signature, but don't know how to do it??
...I'm not quite sure I understand your question. It is my signature already and works fine from my view, does it show up weird for you?
I'm in southern AZ..
"Good job, guys. "
Posted: 02:27 pm Sep 17 2016
"Good job, guys. "
I quoted your post. It shows up in your post, not as a signature. See where mine says "THANK YOU, JulienD, for your hard work on the site!"? That is some info I put in the signature field on my profile. That is why I asked.
Thanks.
Posted: 02:28 pm Sep 17 2016
by Friedom
"Good job, guys. "
Thanks.
Ironically, I don't see that signature on your posts. So I think yours is set up through the website, but mine is setup through Tapatalk (The app that I use for forums).
"Good job, guys. "
Posted: 03:32 pm Sep 17 2016
Ah. OK. That is different.
Posted: 05:48 pm Sep 17 2016
by Friedom
So any one know if the crank is the same for late E and H series? Numbers were the same on rmatv, but it didn't seem all that precise.
"Good job, guys. "
Posted: 08:43 pm Sep 17 2016
by Tedh98
Looks like different p/n's to me.
Posted: 10:52 pm Sep 17 2016
by Friedom
Tedh98 wrote:Looks like different p/n's to me.
Where are you referencing? Just want to be clear.
Edit: yup,they're different numbers according to Partzilla and CMSNL.
Guess I'll continue sniffing ebay.
"Good job, guys. "
Posted: 11:28 am Oct 19 2016
by Friedom
Bump: anyone have a crank - or even a bottom end from an E series for sale?
"Good job, guys. "
Posted: 09:17 pm Jan 08 2017
by battery
Friedom wrote:Bump: anyone have a crank - or even a bottom end from an E series for sale?
I should be able to help you out. I cant seem to send or received PM's, but my e-mail is damage.inc@mchsi.com, if the site will display it...
I have a "90 engine bottom, but it needs to be disassembled. I can move it up on my schedule if you are still looking.
Posted: 11:49 pm Jan 11 2017
by Friedom
Thanks. I was able to source a good looking 89 crank on ebay. Had it sent directly to RB and he affirmed it looked good and rebuilt it.
It's now sitting on the shelf with all the rest of the disassembled engine.
I'm starting to get excited about this bike again! Think I'll go read the engine assembly section again..
"Fun Wheel Drive"
Posted: 10:28 am Jan 13 2017
by Dekon
Julien D wrote:Bummer. What year is your bike? They changed the flywheel mount at some point during the E series. Can't recall what year, but the earlier uses a bolt that threads into the flywheel side, the later uses a nut and the crank half on the flywheel side is threaded on the outside. Probably won't matter as long as you get the right bolt/nut to go with.
Just found this in reference to Julien's post.
http://www.kdxrider.net/forums/viewtopic.php?t=11286
