what is good for cleaning top end parts?
hey guys what is good for cleaning the kips gears and the main valve. and cleaning all the carbon out of the cylinder. another thing what is good for cleaning carb. i know what your going to say "Carb CLeaner." but in my manual it says dont use carb cleaner because it will eat away at the small plastic functional non removable parts. thanks guys
- Ryan
are you goona take the whol thing apart? i would especailly if you have never done it before. I just did mine and it had alot of carbon on the power valves, clean the metal parts with carb cleaner or parts cleaner and the plastic stuff with brake cleaner or other cleaners that dont eat plastic. Just spraying down the kips vavle, wont do much.
2001 kdx220
1987 honda xl250
1987 honda xl250
yeah i am doing a top end rebuild and cleaning the whole gears and taking them out and cleaning them. doesn't seem to hard to get apart, but putting back together is the harder part, like when you see something in the cylinder that you never saw because of spooge or junk. taking all the valves out cleaning them putting it back together with a wiseco, and then the desert pipe and reeds go on. oh yeah by the ways how many times do you have to heat cycle a forged piston, and for how long. i thought that brake cleaner ate away at plastic?
get a lift, fat chicks can't jump!
when in doubt gas it!
Cleaning
Being as how I just got done doing this this past weekend....
Right or wrong I just used gasoline and a mild scotchbrite pad and toothbrush. Took some scrubbing but the KIPS came clean. Granted, my KIPs and everything else was pretty clean compared to some of the photos I've seen on carboned up valves and what not. Piston is going bye-bye since the new Wiseco just arrived this afternoon so I didn't bother cleaning it.
I think we all need T-shirts or something...
Mark
Mark
- KDX220PHIL
- Colorado Mike
I heard over on that other site a bunch of guys were pitching some solvent that Subaru sells. S'posed to make quick work of cleaning up the KIPS. I don't know the name of it but am sure if you asked the parts dude at one of those dealers he could find it for you.
- KDXer
I accidently found Suburu Upper Engine and Combustion Chamber Cleaner and it was amazing how well it worked. It's designed to spray into the intake of the running engine of a car. I just sprayed and soaked the pieces and the came up looking brand new. Great product but it isn't real cheap.
(Accidently) A mate of mine grabbed 2 cans from his work to do his car but never used them.
- Mr. Wibbens
Yamaha Combustion Chamber Cleaner works really good!
Sprayed a lil on top of the piston and let it soak a minute then took a toothbrush and the carbon started disolving
For the carb, Berryman's is the BEST! Just be sure and get all the O-rings and plastic pieces off before you soak it. Carb will come out looking spankin' new
- Mr. Wibbens
Stuff I have comes in a gallon can and has a small parts basket that lets you dip the whole carb in at once
Mr. Wibbens:
Where do you (did you?) get your Yamaha stuff? The local dealer never heard of it..wasn't interested in ordering it, either.
PuLEEZE don't tell me you got it from the guy that's not there anymore!!??
KayD: What does 'Not cheap' mean?
Kerosene works. Not in the 'wet-n-wipe off' category, but it works.
Oven cleaners work on carbon pretty good. They're hard on aluminum, though. Not the sort of thing you want to hose your cylinder down with...let it sit overnight..and not expect some damage.
- Mr. Wibbens
Uhhh, well...
I'm not sure if he has a shop (All Cycle ATV?) anymore or not
Last time I was in Naumes he was working behind the desk!
I can't imagine them not being able to get you some
I just Googled this:
http://www.powerpartsplus.com/clearance ... 904_1.aspx
So...how much of a case do YOU want to spring for...?
- skipro3
- Mr. Wibbens
Everytime I've bought some it was around $8 a can!
I'd go for a half case
I might have a lil bit if you'd like to try it out first, only cost ya a beer and some leftovers
- jackpiner57
I used lemon scented oven cleaner. Worked OK still had to scrub with a wire brush though. The plus is that my KIPS smell great now. Wear rubber gloves and safety glasses. Oh, and wash it off any aluminum within 10 min.
2002 KDX200
2005 KX85
2005 DL650K5 V-Strom
NETRA
AMA
Montshire Trail Riders
Vermont Motocross Association
I got stopped for speeding and the cop asks me "Don't you know the speed limit is 55 miles per hour?" So I said "yeah but I wasn't gonna be out that long."
2005 KX85
NETRA
AMA
