The kdx donor. I've never seen a bike so ragged out in my life.
The seller said it has a fresh top end (don't they all?) but it wouldn't start/had no compression. Didn't take long to figure out why
The cylinder is currently at 66.75mm. Unfortunately it has a big divot in the cylinder wall so it will need bored out and replated to fix that. Also the con rod big end bearing has a ton of side to side play, so I'll be need to address that too.
And here is the kx. It runs really well still so I've just been riding it around while my Husky 125/165 is down for a crank rebuild. Plus a titled frame that I'll be fitting the kdx engine in to and will eventually plate.
After getting it woods ready (skid plate, fat bars, bark busters, gummy rear tire, uhd tubes, spark arrestor, etc. )
Stuck an 03+ kickstand on. Had to drill a new hole and use both spacers from the hardware kit but it went on pretty easy.
The biggest change to the bike is the front forks. I have a yamaha wr250f that I put some newer kyb sss forks on and I had both bikes side by side and damn those forks upper look nearly identical. Checked it with a caliper and they are. Sweet. So here it is with 1 oem fork (silver) and one yamaha sss fork (gold). The previous pic shows it all together with both forks.
The forks are 2006. I had to use the yamaha front wheel, axle, and spacers for the brake rotor to line up, although I'm sure someone could just make new spacers for the kawi wheel.
And here is a video riding some stupid trails that a 125 probably shouldn't be used for. *edit* here is the link since it doesn't seem to want to embed
[youtube][/youtube]
